03-02-2017 02:35 AM
I've got some problem using prime 3.1 : the ip address of some clients are not available while others are ok
Don't undestand why : clients connected to the same switch, with the same configuration (static ip)
Any idea to help me ?
05-08-2017 05:00 AM
this is a bug CSCvb71114.
It's fixed with Patch 5.
Tobias
11-08-2018 10:57 AM
Did you ever get this problem resolved?
11-12-2018 05:55 AM
Hi There,
If you are not into the same scenario as mentioned in the bug, you need to check the switch/router to which the clients are connected.
the switch/router should be managed in Prime Infras and the arp entries for the endpoints should be updated and available in the router.
Hope this helps.
Gautami.
