08-20-2019 11:03 PM - edited 08-20-2019 11:04 PM
Hello All
My PI 3.5 installation has the latest Update 3 installed and I just wanted to install the latest Upgrade 3.5.1. This failed, because the /var was full (once again....).
I dug a little bit deeper and discovered that logrotate is not working in this version. Because of that is my /var/wtmp > 2.7 GB and the /var/messages > 0.5 GB.
Luckily I had a VM Snapshot and could restore the working installation (upgrade failed and left me with a broken installation).
I manually cleaned the wtmp file by doing this:
#enter shell: shell #get root sudo su - #write an empty new wtmp file (this can take a minute) cat /dev/null > /var/log/wtmp
After this I started to troubleshoot the logrotate. It seems that SELINUX is blocking the run (or a faulty logrotate.d/syslog config file).
Error messages on CLI:
[root@cpi1 logrotate.d]# logrotate -df /etc/logrotate.d/syslog reading config file /etc/logrotate.d/syslog Allocating hash table for state file, size 15360 B Handling 1 logs rotating pattern: /var/log/cron /var/log/maillog /var/log/messages /var/log/secure /var/log/spooler forced from command line (no old logs will be kept) empty log files are rotated, old logs are removed considering log /var/log/cron error: skipping "/var/log/cron" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. considering log /var/log/maillog error: skipping "/var/log/maillog" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. considering log /var/log/messages error: skipping "/var/log/messages" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. considering log /var/log/secure error: skipping "/var/log/secure" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. considering log /var/log/spooler error: skipping "/var/log/spooler" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. [root@cpi1 logrotate.d]# [root@cpi1 logrotate.d]# run-parts /etc/cron.daily/ /etc/cron.daily/cronCleanup: find: ‘/localdisk/tftp/RUNNINGCONFIG*.cfg’: No such file or directory find: ‘/localdisk/tftp/STARTUPCONFIG*.cfg’: No such file or directory find: ‘/localdisk/tftp/2019*.cfg’: No such file or directory find: ‘/localdisk/tftp/2018*.cfg’: No such file or directory /etc/cron.daily/logrotate: error: Ignoring ADE because of bad file mode - must be 0644 or 0444. error: Ignoring charon.logrotate because of bad file mode - must be 0644 or 0444. error: skipping "/var/log/boot.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/opt/CSCOlumos/logs/ftpadmin.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/opt/CSCOlumos/logs/tftpadmin.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/var/log/squid/*.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/var/log/cron" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/var/log/maillog" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/var/log/messages" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/var/log/secure" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/var/log/spooler" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/var/log/vsftpd.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/var/log/xferlog" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/var/log/wpa_supplicant.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/var/log/yum.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/var/log/wtmp" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. error: skipping "/var/log/btmp" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation. [root@cpi1 logrotate.d]#
Digging a little bit deeper now, I think I should be able to solve it (temporarily) with setting permissions inside the /etc/logrotate.d/syslog file.
08-22-2019 12:07 AM - edited 08-22-2019 12:08 AM
Did you manage to fix this issue? Recently I've noticed I have the same problem on two of my CPI installations.
08-22-2019 12:45 AM - edited 08-22-2019 12:49 AM
See my new messages.
08-22-2019 12:46 AM - edited 08-22-2019 12:49 AM
Issue is the /var/log/wtmp file, which uses nearly 80% of the partition. First I have to clean this.
#enter shell: shell #get root sudo su - #write an empty new wtmp file (this can take a minute) cat /dev/null > /var/log/wtmp #In my case the messages file was also already > 500 MB, I'm not sure yet if I should also clean it. wtmp file was 2.7 GB though.
Now that this file is clean, time to fix the not working logrotate function.
Fixed it (probably until the next patch/major release) by editing the /etc/logrotate.d/syslog file (plus all the others for good measure, where I also received an error message). I added the line ' su prime gadmin '
[root@cpi1 logrotate.d]# vi syslog /var/log/cron /var/log/maillog /var/log/messages /var/log/secure /var/log/spooler { su prime gadmin missingok sharedscripts postrotate /bin/kill -HUP `cat /var/run/syslogd.pid 2> /dev/null` 2> /dev/null || true endscript } # To safe enter :wq # It will logrotate all the files mentioned in this file within the next 24 hours automatically # To manually rotate enter 'run-parts /etc/cron.daily/'
Please note, this will NOT cleanup the used space, as the files will not be compressed nor removed (they will be kept for 1-4 weeks). So if you need space now, remove the files with a .1, .2, .3 or .4 ending after logrotate has run.
Please also note, logrotate can only successfully run if there is at least some space left. If the partition is completely full, clean the wtmp file first (or any other large file).
To rotate wtmp and btmp, edit the /etc/logrotate.conf to:
# other lines removed /var/log/wtmp { su root guser monthly create 0640 root guser rotate 1 } /var/log/btmp { su root guser weekly create 0600 root guser rotate 4 }
# other lines removed … … .
08-22-2019 12:54 AM
Thank you for sharing this!
Now I started the 3.5.1 maintenance upgrade and will see if it's fixed there. If not, I will try your solution.
08-22-2019 03:01 AM
Upgrading to 3.5.1 did not resolve the issue, so I used your method.
Thanks again!
11-20-2019 08:24 AM - edited 11-20-2019 08:32 AM
Very good write up patoberli, I've recently hit this and found the following bugs
CSCvp38163
Although the bug does state /secure files will take/use all the var space the description includes the wtmp file also.
PI version 3.6 includes the fix for this issue
Your workaround did the trick for me :)
Kind Regards Jon
01-29-2020 05:06 AM
Thanks for posting this. I ran into the same issue with PI 3.6 patch 1 - primary server in an ha pair ground to a halt with 100% usage on /dev/mapper/smosvg-varvol. I contacted TAC who referred me to this thread - the fix worked for me.
cheers
Andy
06-05-2020 01:36 AM
Same problem here.
NCS did not start
xxxx/admin# ncs status
Health Monitor Server is stopped.
Database server is stopped
FTP Service is Stopped
TFTP Service is Stopped
Matlab Server is Stopped
Matlab Server Instance 1 is Stopped
Matlab Server Instance 2 is Stopped
Matlab Server Instance 3 is Stopped
NMS Server is stopped.
Coral Service is stopped..
WSA Service is stopped..
SAM Daemon is stopped.
DA Daemon is stopped.
Compliance engine is not running
/dev/mapper/smosvg-varvol 3966144 3966144 0 100% /var
[root@xx log]# cat boot.log
[ OK ] Started Import network configuration from initramfs.
Starting Create Volatile Files and Directories...
[FAILED] Failed to start Create Volatile Files and Directories.
See 'systemctl status systemd-tmpfiles-setup.service' for details.
Mounting RPC Pipe File System...
Starting Security Auditing Service...
[root@xxxlog]# ls -lha
total 3.7G
-rw-r-----. 1 root guser 2.6G Jun 5 09:06 wtmp
after deleting wtmp
[root@vbsgcpi01 log]# rm wtmp
rm: remove regular file ‘wtmp’? y
ncs started again.
implemented the workaround.
now file size of wtmp looks stable
-rw-r-----. 1 root guser 129K Jun 5 10:35 wtmp
-rw-r-----. 1 root guser 957K Jun 5 10:26 wtmp.1
