Prime Inf 2.2 and SNMP connectivity
cgarringer
I am running Prime Infrastructure 2.2.    I have about 8 devices out of 180 that keep saying "SNMP connectivity failed" but when I run Verify Credentials all the credentials, including SNMP are good.     How can it check and OK the SNMP credentials but fail SNMP connectivity?
Marvin Rhoads
Sometimes an SNMP timeout can occur. You can try changing the threshold for those devices and seeing if that helps.
Another thing to consider would be capturing the traffic and seeing what's going on there. (You can use tcpdump from the PI root shell.)
IGOR SPANZ
you can check whether SNMP engineID are configured if that immediately on all devices are, it must change you or delete
