Prime infra 2.1 : SNMP Authentication failure polling
Didier Gilli
Dear all,
I post this message because we have some trouble during SNMP V2 poll on all our switches.
We took care to deploy the good snmp credentials into the "Operate-> discovery settings" and even into the "Administration -> sys settings -> SNMP credentials".
The issue is that during the poll phase the SNMP credential "default" is sent to all switchs that is causing a lot of "authentication failure" traps (a packet capture has been done to confirm this trouble).
The correct credential is sent in parallel of this request that is ok.
The OID requested is the 1.3.6.1.2.1.1.6.0 (which seems to be the "sysLocation" value). We already tried to restart the NCS services but trouble is still present.
thank you in advance for your support,
regards,
SebastienJ
AFROJ AHMAD
Hi Sebastien,
First  add  the "SNMP RW"  community  ,if you have defined only RO till now.
second:
Go to Administration > System Settings > SNMP Settings and  then increase the
Reachability Retries  to 3     Reachability Timeout  to 14
Thanks-
Afroz
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hello Afrahmad,
we tried but unfortunately no success with RW community.
We also tested before to place bigger timeout and more retries but no more result at all.
 the only thing that is seems to work for the moment is to configure on our switchs the community name "default" but it is not a viable solution for us unfortunately.
sebastien
