Prime Infra 3.2 CSR generation with 4096 bit length
jayage
Hi guys,
does anybody know if it is possible to generate a CSR in Prime Infrastructe 3.2 with key length of 4k?
Our CA admin request that and I didn't find any additional parameter for the command I used to generate.
I executed:
ncs key genkey -newdn -csr CSRFile.csr repository myRepository
bastianbrachner
Hello johaas123,
I have/had the same issue,  I generated a 4k.csr on another linux server for my PI3.2.
Bastian
bastianbrachner
Hello johaas123,
Bastian
