Highlighted
Beginner
Prime infra 3.5.1 HA stuck in secondary syncing and loose Gui access
Hi all,
Our new deployment of prime infrastructure with HA don't work. The secondary node stuck in secondary syncing and the vip ip GUI is not accessible.
Someone can help me ?
Thx all
5 REPLIES 5
Highlighted
VIP Mentor
Re: Prime infra 3.5.1 HA stuck in secondary syncing and loose Gui access
is the primary working as expected?  how is your network between Primary and Secondary? any other FW  involved or just Layer 2?
Can you explain is this new setup, or after HA build having issue ?
some FAQ for reference :
https://community.cisco.com/t5/networking-documents/cisco-prime-infrastructure-faq/ta-p/3149669
BB
*** Rate All Helpful Responses ***
Highlighted
Beginner
The primary, secondary node and vip are on the same subnet. No firewall, prime version 3.5.1 (standard ) under vmware esxi 5.5. This is  a new deployment (fresh install), all the service run from the primary and secondary... but the secondary node show syncing from more than 8 hours from when we configured HA.
Thx for reply.
Highlighted
Hi Nicoles,
This is HA design.
For HA healthy state, primary  role would be Primary Active and Secondary server role would be Secondary sync. This means database is in sync with primary.
Also, When secondary server is in secondary standby role, only health monitor page is accessible due to fact that database is only available to sync data.
Please refer HA document for understanding different states of server in HA.
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-5/admin/guide/bk_CiscoPrimeInfastructure_3_5_AdminGuide/bk_CiscoPrimeInfastructure_3_5_AdminGuide_chapter_01010.html
Hope this clarifies the question.
Highlighted
Beginner
us i told you in the object we loose gui access from the primary node (and VIP). This isn't a normal behaviour...?
Highlighted
provide ncs ha status from cli session of both primary and secondary server.
Ensure all services are running in primary server. ncs status.
Also, do not keep HA failover setting as automatic since it can lead to split brain scenario where network hiccup between the pairs can make both server take primary role if no response received within specified time between each other.
Also, it is very important to note network throughput between HA pairs must be 100Mb/sec and consistant since oracle db data is shared and missing of certain files can cause oracle to be be move to offline which cause service to halt.
Content for Community-Ad
