02-22-2020 01:34 PM - edited 02-22-2020 01:35 PM
Hi all,
Our new deployment of prime infrastructure with HA don't work. The secondary node stuck in secondary syncing and the vip ip GUI is not accessible.
Someone can help me ?
Thx all
02-22-2020 02:26 PM
is the primary working as expected? how is your network between Primary and Secondary? any other FW involved or just Layer 2?
Can you explain is this new setup, or after HA build having issue ?
some FAQ for reference :
https://community.cisco.com/t5/networking-documents/cisco-prime-infrastructure-faq/ta-p/3149669
02-23-2020 03:57 AM - edited 02-23-2020 03:59 AM
The primary, secondary node and vip are on the same subnet. No firewall, prime version 3.5.1 (standard ) under vmware esxi 5.5. This is a new deployment (fresh install), all the service run from the primary and secondary... but the secondary node show syncing from more than 8 hours from when we configured HA.
Thx for reply.
02-23-2020 09:59 PM
Hi Nicoles,
This is HA design.
For HA healthy state, primary role would be Primary Active and Secondary server role would be Secondary sync. This means database is in sync with primary.
Also, When secondary server is in secondary standby role, only health monitor page is accessible due to fact that database is only available to sync data.
Please refer HA document for understanding different states of server in HA.
Hope this clarifies the question.
02-24-2020 01:05 AM - edited 02-24-2020 01:16 AM
us i told you in the object we loose gui access from the primary node (and VIP). This isn't a normal behaviour...?
02-24-2020 06:01 AM
02-28-2021 01:38 PM
I know this is an old ticket, but I had the exact same issue so this might help someone else.
The Routing Table on my Primary Node had updated with a static route entry to point 10.0.0.0/255.0.0.0 to gateway 0.0.0.0. I removed this entry and everything started functioning properly.
