Prime Infrastructure 2.0 Console in AZERTY (French)
Hi.
For test purpose, I deployed Prime Infra Express VM ova file on my VMWare server. I can't find a way to change keyboard layout to French AZERTY on the console.
Does anyone know how to do that on console command line ?
Thank you
Philippe Goossens.
5 Replies 5
Marvin Rhoads
It's not a "supported" change but the OS underneath Prime is RedHat Linux. I looked on my 2.0 system and see the following:
ade # uname -a
Linux prime 2.6.18-238.1.1.el5 #1 SMP Tue Jan 4 13:32:19 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
ade #
ade # pwd
/etc/sysconfig
ade # cat keyboard
KEYBOARDTYPE="pc"
KEYTABLE="us"
ade #
I would hazard a guess that if you change the KEYTABLE variable to "fr" and restart the system you might see it flip to AZERTY.
Bonne chance!
Hi Marvin.
It doesn't seem to be the same interface... I have a kind of Cisco console and no access to uname command.
prime20/admin# sh ver
Cisco Application Deployment Engine OS Release: 2.0
ADE-OS Build Version: 2.0.6.003-px-build
ADE-OS System Architecture: x86_64
Copyright (c) 2005-2010 by Cisco Systems, Inc.
All rights reserved.
Hostname: prime20
Version information of installed applications
prime20/admin#
Philippe,
You are in the ADE-OS (Application Development Environment Operating System) shell. It has only commands specific to the Cisco application at a high level available.
For my commands, you need to drop into the underlying OS shell with the "root" command. At that point, you are logged in as a Linux admin with root superuser privilege.
This change is pretty benign but beware that change you make to the OS level without TAC direction are at your own risk.
Hi Marvin.
Thank you for your help. I can't fin a way to login as root, but it doesn't matter anymore. I can log in through ssh with putty and it's in french AZERTY.
Philippe
Thanks for that really good information. Now I have access to the linux. This is more comfortable.
Just have to enter "root-enable", create a new password and after that, I can enter "root" to access "ADE". NICE :)
