Prime Infrastructure 2.1 - Hardware Inventory
tobiasdreyer
I used LMS before to generate custom reports. Now with Prime I'm a little bit annoyed of the reporting functions.
I want to generate a inventory report for all 1841 Routers where I can see, which type of HWIC/WIC Modules are used.
Something like:
Name - IP Address  -  Module Type - SN
Is there a way to do this in PI 2.1?
thx
AFROJ AHMAD
AFAIK,
unfortunately , this feature is not available at the moment  :(
Thanks-
Afroz
***Ratings Encourages Contributors****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
