02-07-2017 12:14 AM
Hello all,
Can any one confirm if Prime Infrastructure 2.1 supported on VMware vSphere Hypervisor 6.5 free version ?
We got Cisco UCSC-C220-M4S as hardware for Cisco Prime Infrastructure only. The plan is to install VMWare vSphere Hypervisor 6.5 on UCS-C220-M4S then install Prime Infrastructure 2.1.
Will it work fine ?
Solved! Go to Solution.
02-07-2017 12:53 AM
No
Checkout the link below and look for 'Prime Infrastructure Minimum Server Requirements'
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-1/quickstart/guide/cpi_qsg.html
M.
02-07-2017 12:53 AM
No
M.
02-07-2017 10:25 PM
Thank you Marce1000 and Marvin to reply here.
It was my bad, Prime Infrastructure version is 2.2 not 2.1. and from following link, PI 2.2 has support on EsXi 5.5 (which is available as free version from vmware.com )
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-2/quickstart/guide/cpi_qsg.html#pgfId-97386
Can any one confirm if PI 2.2 works fine with free version of ESXi 5.5 ?
File name for free ESXi 5.5 on vmware is
VMware-VMvisor-Installer-5.5.0.update03-3116895.x86_64.iso
02-07-2017 05:34 AM
Adding to M's correct reply - even the current PI 3.1 is supported only up through ESXi 6.0.
Reference:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/quickstart/guide/cpi_qsg.html#pgfId-121806
PI is one product that is rather particular about heeding the requirements. If you depart from them, you may get some very hard to fix problems.
