Prime Infrastructure 2.1: Report - Device - Inventory
Hi there,
we want to have an inventory report of your device database.
The infrastructure is a wild mix of Catalyst 6500er, 3560X, 3750X, N7K, N5K, WLC, etc.
We are using the prime infrastructure 2.1 Report Launch Pad and the API site. The maximum we get of a N7K:
UDI serial number
FAN serial number
The whole Module serials numbers are missing. How do we get this data?
br,
chris
AFROJ AHMAD
Hi Chris,
check the below report ::
Report > Report Launch Pad > Device > Detailed Hardware > Detailed Hardware Report Details
Hope you will see the data ,you are interested in.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
we tried that too, but the same.
you will get only serial number of FAN and Chassis - no module
Any other idea?
i think we will not be able see the module serial no.. i checked in my server too.. i can see the chassis serial no. only    :(
Thanks-
here is an update:
There are more than one Report you need to start to get data for Device, FAN, Power Supply, Module - look at these reports:
Report > Report Launch Pad > Device > Inventory
Report > Report Lauch Pad > Device > Wired Detailed Device Inventory
Report > Report Lauch Pad > Device > Wired Module Detail > Wired Module Detail Report Details
SFPs and GBICs cannot be reported til now - there are working on it.
br,
chris
