Prime Infrastructure 2: Device Typ not updated after replacement in Device Work Center
bastianbrachner
I've found something confusing. Please have a look below. Has anyone the same feature or is familiar with that?
We replaced a 4400-series WLAN controller with a 5500 series controller, the UDI information was discovered correctly but the general information was not updated.
I got it uptodate while exporting exporting the device and doing a bulk import. I also recognized that the credentials were not the correct ones for the new controller. Could it be that the credetial mismatch was cause? Is snmp access not enough to update the inventory information?
Bastian
AFROJ AHMAD
Hi Bastian,
It can only be  because of "Incorrect credentilas Only"
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
