10-05-2016 04:34 PM
Hello everybody:
I am trying to set a backup on PI 3.0 using SFTP repository, however I am getting the following error when checking the repository:
cpi02-to3-corp/admin# show repository SFTP 6 [6637]: transfer: cars_xfer.c[201] [admin]: sftp dir of repository SFTP requested 6 [6637]: transfer: cars_xfer_util.c[2089] [admin]: resolved server to 10.1.31.121 3 [6637]: transfer: cars_xfer_util.c[2105] [admin]: libssh2 session startup failed % SSH session setup error
The repository configuration is the following:
repository SFTP url sftp://10.1.31.121/cpi-backups// user cpisftp password hash 3c6189f3c5eef5e3d657adb2c28886c887a714ea repository defaultRepo url disk:/defaultRepo
I login to the SFTP server manually and the password is less than 17 characters with no special characters:
ade # sftp -c aes256-cbc cpisftp@10.1.31.121:cpi-backups<mailto:cpisftp@10.1.31.121:cpi-backups> cpisftp@10.1.31.121's<mailto:cpisftp@10.1.31.121's> password: Connected to 10.1.31.121. Changing to: /cpi-backups
I found the following in the SFTP server logs:
Sep 23 08:34:11 ossftp1-to5-corp sshd[11890]: fatal: no matching cipher found: client blowfish-cbc,arcfour128,arcfour,cast128-cbc,3des-cbc server aes128-ctr,aes192-ctr,aes256-ctr,aes256-cbc
I have been looking for the Prime documentation but there is not information about the Ciphers that Prime needs to be configured.
I am suspecting PI needs specific ciphers in order to communicate with SFTP server. Has anybody seen this behaivor? Is it a bug? Please let me know if you have any recommendation or suggestion.
Thank you.
Rose
Solved! Go to Solution.
10-06-2016 06:05 AM
@Afroz
In this case, the PI server is the ssh client. I Believe we also had this issue when connecting PI to ISE due to cipher mismatch. I thought it was fixed in PI 3.0 but it may have been 3.1.
rriveraa ,
You could try lowering the accepted cipher strength server-side or possibly bring your PI up to the latest version (3.1.3 as of right now).
10-05-2016 07:24 PM
Hi Rose,
yes , it is a BUG.
10-06-2016 09:31 AM
thanks for including the Bug, I appreciate.
10-06-2016 06:05 AM
@Afroz
rriveraa ,
10-06-2016 09:28 AM
Thank you so much for your answer, I am using PI version 3.0, I wil try with 3.1.3.
