Community Helping Community
386
Beginner
Prime Infrastructure 3.0 optvol running out of space
Hi Guys,
since I update Prime to v3.0.0.0.78 the system volume /dev/mapper/smosvg-optvol  is continously running out of space (usage up to 99%).
I've already tried the NCS cleanup command but that didn't help much. So when Prime's optvol was at 99% and I wasn't able to access the webgui anymore I decided to add another virtual harddrive. After rebooting Prime everthing was fine 'cause the additional 60GB space were allocated (80% of it) to the optvol. The usage from optvol back then was at about 7-10%, perfect so I thougt...
Today, 4-6 weeks later Prime's optvol is at 81% yet again!!!!!
Can anybody help? How to fix that??
Thanks in advance
1 REPLY 1
Highlighted
Beginner
Have you looked document
Have you looked document attached into this discussion. It helped me once while struggling with similar issue in PI2.2.
/Mikko
https://supportforums.cisco.com/discussion/12294121/prime-infrastructure-high-disk-usage
Content for Community-Ad
July's Community Spotlight Awards
