951
Highlighted
Beginner
Prime Infrastructure 3.1 bugs ?
Upgraded from PI 3.0 to PI 3.1
After upgrade I noticed the following things:
- FTP access works totally different now. Different command needed to FTP off the box.  Seems like it wants to only use ftp-user for the username.  I had to change the password for the ftp account on PI and it kept telling me to use that username instead of the one I had before.
- you now have to use "shell" instead of "root" to get to the root shell.
- I seem to have lost information related to our wired switches now: on the dashlet called "client count by association/authentication" I have no wired data shown.  I do have my wireless history still.  I can go back a few months and see that exactly on the day I upgraded to 3.1, the wired data graph stops. (see attached)
- Applying templates to switches seems to have changed.  I can't find where to select an individual switch from my list.
Anyone else upgraded to PI 3.1 and are seeing any of these issues?
Everyone's tags (1)
6 REPLIES 6
Collaborator
  Yeah , but the word is that root-privs have been removed from the "shell" (...);  check  using the
          id
command (at the shell prompt).
M.
Beginner
I had opened a TAC case 2
I had opened a TAC case 2 days ago, and found out you can still get root privileges:
in the cli do
shell
<password>
sudo -s
you will have root control then.  I was able to do the normal pwd,ls,cp, etc.  The TAC engineer had me type in the sudo -s command to do more.
FYI
Collaborator
  - Doesn't work for me : here's a trail
cisco-prime/ciscoadmin# shell
Enter shell access password :
Starting bash shell ...
ade #
ade #
ade # sudo -s /bin/csh
[sudo] password for ciscoadmin:
ciscoadmin is not in the sudoers file. This incident will be reported.
Check your process id , after your 'sudo setup' using ;
              id
at the command prompt; ->  are you sure you are root ?
M.
Beginner
My output:
My output:
CABPRIME/admin# shell
ade # sudo -s
ade # id
uid=0(root) gid=0(root) groups=0(root),1(bin),2(daemon),3(sys),4(adm),6(disk),10(wheel) context=system_u:system_r:unconfined_t:s0-s0:c0.c1023
ade # /bin/csh
[root@CABPRIME ~]#
Collaborator
 - So that probably means
 - So that probably means then that 'admin' is in /etc/sudoers; since I used another account name for admin-tasks upon configuring prime , I guess I am out of luck :-)
Or concluding that root access will still be deprived , if you don't use the default admin account.
M.
Beginner
You just need to create the admin account :
(config)#username admin password  role admin
/admin# shell
ade # sudo -s
ade # id
Content for Community-Ad
July's Community Spotlight Awards
