Robbin Thomas
Prime Infrastructure 3.1 Fault Monitoring Overview Job Aid Now Available
Fault reporting is a key Prime Infrastructure monitoring feature that reports changing conditions that might require additional monitoring, more immediate attention, or action to mitigate or avoid disruption or downtime.
This job aid introduces you to the areas of the application that report aggregated and detailed fault data, including events, alarms, and syslog messages, and to the key method that you use to manage alarm reporting.
Review the Fault Monitoring Overview job aid, which is a PDF-formatted file.
Take a look at other Prime Infrastructure training opportunities!
0 REPLIES 0
