04-21-2019 04:50 AM
Dears ,
I am trying to add Brocade switches to cisco Prime infrastructure 3.2
I have verified the provided credential for CLI and SNMP and also I can ping form the switch to Prime .
once added and sync , I received "SNMP Connectivity Failed"
please advise
04-21-2019 04:59 AM
Firstly i would check the model in compatability list.
Seconds, check the SNMP config on broacade side.
If you have windows, download snmplwalk and try config broacade IP make sure you have snmpwalk working with snmp credentials, if all working then try same setting on prime.
or check the Logs why it failing ?
04-21-2019 05:20 AM
04-21-2019 05:59 AM
here is compatability matrix to check.
