Prime Infrastructure 3.2 - Top N Clients
Weeltin
I have a little issue with our Prime Infrastructure 3.2 installation.
We have installed a standard virtual instance on a Vmware Esxi 6.0 installation.
We have created some virtual domains, and our problems is that when a administrator wants to pull data about the bandwidth usage using the Dashboard / Performance page.
When looking in on the top N clients he can only able to see client ip address, but when switching to username i doesn't display anything.
If he change time frame to more than 6 hours, the client ip address also disappears.
The usernames should be pulled from our WLC, as we use WEB authentication on that.
0 Replies 0
