Prime Infrastructure 3.4.1 and image distribution
Artur Akhmerov
Hello!
A have prime inf. 3.4.1
i'm trying to distribute image from prime to swtiches.
In menu Inventory / Device Management / Software Images
I'm upload firmware to prime, then do  distribute  job for 11 switches with no rebooting.
the job are still in five switches and nothing do else.
 it is normal for prime ?
pieterh
the job status displays it is still running
some devices may not be reachable , this  will slow down because of retries and timeouts
you also need to look into the other options you selected
In prime you have the option to distribute sequential or parallel.
when doing parallel, there is a maximum at same time.
Still running for 48 hours ? normal time for this job 15 minutes.
all devices are available.
What is most interesting - restarting ncs services did not give a result.
The problem was solved in this moment only through halt and power on
