Prime Infrastructure 3.5 - Recent Config Change and Top N WAN Interfaces by Utilization Dashlets Not Poplulating
BRANDON PORTER
Recently upgraded our Prime Infrastructure installation from version 3.3 to version 3.5 with all critical fixes and device updates installed. Added these two new Dashlets (Recent Config Changes and Top N WAN Interfaces by Utilization) which are not populating. Synced all 900+ managed devices in Prime following upgrade.
Wondering where Prime is pulling the configuration changes from and if there are any System Settings, device or configuration archiving settings that need to change for the Recent Config Changes dashlet to populate.
Also not sure how the Top N WAN Interface by Utilization populates and not sure if any System Settings or device configuration changes are needed to get that dashlet to populate.
cexc
Hi. You need to set logging trap to notification as the alert Prime needs is a syslog trap as below:
%SYS-5-CONFIG_I: Configured from console by ......
This is also required for auto configuration archive after a config change.
