Prime Infrastructure 3.6
ssambourg
I have a problem on Prime Infrastructure 3.6 last patch.
For some switches, clients appears for others switches clients don't appears.
I check that there is connected client on theses switches where client don't show up in Prime and mac-address table is not empty for these switch ports.
It happens on different hardware model.
What could be a root cause of that ? My snmpwalk from Prime Infra to switches where I have the problem seems to be correct but I assume that the SSH connection is used to gather the clients mac address table.
I also tried to re-sync these switches, suppress them from my inventory and add them again. I check on my firewall between prime and switches and no one packet is dropped..
0 Replies 0
