08-31-2020 08:48 AM
Hi Guys,
i configure the Prime Infra 3.7 HA with Virtual IP address. My secondary is not taking over and i am facing the following logs in The Primary Health Monitor details. when i turn off the Primary instance, Virtual ip is not reachable. no GUI accessable from Secondary.
Aug 31, 2020 05:27:30 PM OldEc | Health Monitor Available | Health Monitor Started |
Aug 31, 2020 05:23:42 PM OldEc | HA Configured but not Enabled | Administrative Shutdown(with switchover) |
Aug 31, 2020 04:58:40 PM OldEc | Primary Active | The Secondary server (172.16.25.6) is not functional and hence continue with the primary server (172.16.25.5). |
Aug 31, 2020 04:58:19 PM OldEc | Primary Active | Failover is in progress in secondary server (172.16.25.6). |
Aug 31, 2020 04:58:19 PM OldEc | Primary Active | Secondary Health Monitor becomes reachable |
Aug 31, 2020 04:40:24 PM OldEc | Primary Active | Primary Prime Infrastructure Server started successfully as active |
Aug 31, 2020 04:40:13 PM OldEc | HA Configured but not Enabled | Prime Infrastructure started successfully. Prime Infrastructure server state : Primary Alone |
Aug 31, 2020 04:24:29 PM OldEc | Health Monitor Available | Health Monitor Started |
Aug 31, 2020 04:17:40 PM OldEc | HA Configured but not Enabled | Administrative Shutdown(with switchover) |
Solved! Go to Solution.
09-01-2020 10:02 PM
Hi Leo Laohoo,
1- I removed the HA
2- refresh the DB on the Secondary.
3- Configure the HA Again.
Problem solved.
Thanks for your support.
08-31-2020 03:54 PM
SSH or console into the secondary and post the complete output to the command:
ncs status
09-01-2020 10:02 PM
Hi Leo Laohoo,
1- I removed the HA
Problem solved.
