Prime Infrastructure Export Devices
We have Prime Infrastructure 3.0 in our environment. We have added the devices to the Prime for management. Some of the devices have failed SNMP string, some are not reachable, most of them have been discovered. Now we need to extract the exct device details which are shown in Inventory of Prime. We need to verify if we have added all our devices in Prime.  For that we need to export all the devices in Excel. In the Exported excel file, we also need all the information which is displayed in Inventory for each device wiz Hostname, Admin Status, Last Inventory Collection details etc. At this moment we are getting the data in the same format used for Bulk Import excel file. Is there any way to export the device data as it is from Device Inventory?
Mark Malone
Have you tried to run a inventory report that shpould provide that
 / Reports / Report Launch Pad / Device / Inventory
Mark Malone
Hi Marlon,
Thanks for the reply.
The inventory reporting is good option.
Thanks. The report is exhaustive.
SS2020
have you sort this issues yet? how did you convert the CSV file please?
I am having issues with exporting the CSV file to the prime it keep fails
