10-05-2014 04:21 PM
Hello, I purchased license prime infrastructure ver. 1 a year ago and never use it. Now i have prime infrastructure ver.2,
My Question is : Can I use license prime infrastructure ver.1 to my new prime infrastructure ver.2 ?
Solved! Go to Solution.
10-05-2014 06:05 PM
10-05-2014 06:05 PM
Yes.
10-05-2014 09:11 PM
Do i need to upgrade or update it first or just put the license in ?
10-06-2014 01:36 AM
None.
Start from scratch. If you upgrade from version 1 to 2.1, you need to do a lot of "hops". It is a lot easier (and faster) to just start from scratch and install 2.1 into your VM.
Once you're done, put the license in.
10-06-2014 01:53 AM
Thank you, gonna try it
