PRIME Infrastructure OVA co-residency with CUCM on UCS
dlongworth
Hallo All.
Has anyone installed the PRIME Infrastructure OVA alongside CUCM on a UCS?
I've been looking at this document
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Sizing_Guidelines but it is vague on PRIME Infra.
Also, the CUCM I am installing alongside is v8.5
Any thoughts?
Cheers
David
Marvin Rhoads
You should consider Prime Infrastructure as a "non-U / 3rd-party application" and accordingly it requires VMware vSphere as the hosting hypervisor.
Hi Marvin,
Thanks for the pointer. Is there some documentation (like the UC virtualization one) that describes what is and is not supported as far as co-residency is concerned for Prime Infrastructure?
Also, if it requires dedicated cores etc same as the UC environment.
Kamran
The PI documentation is lagging a bit - the only requirements for the current release are what's in the Quick Start Guide here.
There is no requirement for dedicated cores. As long as your VM meets the hardware specification of the QSG, your installation should be OK. (Of course, it doesn't hurt to provide more than the minimum requirements.)
