10-22-2019 11:55 PM
I've recently inherited an existing Prime Infrastructure server and have been struggling to get my head around how to silence some spurious alerts. At present there is a WLC in the network that is using a single Ethernet link into the network, with the other 7 interfaces unused and unconnected. PI however continues to raise monitoring alarms stating those interfaces are down, which is pointless since I dont care that about that.
My question is then where do I look to tweak this - 'monitoring policies', 'alarm policies' or somewhere else?
10-23-2019 12:43 AM
You need to edit setting not to monirot those interface which is not connected - same with other monitoring system example solarwinds, if you ask to monitor all ports, NMS job to send alert, its our task to disable them if not configured or used.
here is the guide for reference :
10-23-2019 01:08 AM
Thanks for that link.
Is there a way for me to trace which policy an alert went through?
