Prime INFRASTRUCTURE SNMP traps
Peter Suchy
PRIME INFRASTRUCTURE does not relay all SNMP traps from WLC. Specially the high-availability related SNMP traps. WLC generates the traps, but the PI does not relay them.
WLC HW version              5508
WLC SW version               8.0.120.0
PRIME SW version           2.2.0.0.158
Could you advice for some fix?
AFROJ AHMAD
looks like it is not supported
https://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjQj5iTgZTKAhUQjo4KHTIYDdoQFggcMAA&url=https%3A%2F%2Fwww.cisco.com%2Fc%2Fdam%2Fen%2Fus%2Ftd%2Fdocs%2Fnet_mgmt%2Fprime%2Finfrastructure%2F2-2%2FTrapsAndSyslogs%2FPrimeInfrastructureSupportedSNMPTrapsAndSyslogs.xls&usg=AFQjCNHylSIa_T9cQ9bI3oxAQyJkBfcv8g
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
