Prime Infrastructure upgrade problem
CH.Y
I tried to upgrade a cisco prime infrastructure (VM) from the version 3.4 to 3.5. The Upgrade finished, but it seems that a problem has occurred with the database restoration as you can see in the captures : 1-2-3
I tried to restore with a backup that I took before upgrading, that didn't work also. (capture : 4)
The same thing happened when I tried to upgrade from 3.4 to 3.6
Any idea ?
Sincerely yours.
0 Replies 0
