No LMS 4.1 is not supported on ESXi 5.0. LMS 4.1 supports the following Virtualization Systems:
•VMware ESX server 3.0.x
•VMware ESX Server 3.5.x
•VMWare ESX Server 4.0.x
•VMWare ESX Server 4.1
•VMWare ESXi Server 4.0
•VMware ESXi Server 4.1
•Hyper V Virtualization (As an installable in Windows 2008)
For more details check:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/install/guide/prereq.html#wp1119955
On a side note, though a OVF/OVA file may be an issue, but you can try to install LMS 4.1 on a virtualized Win/Sol guest OS host, where it should work mostly. But for any issues further, Cisco or TAC may refer to this as an unsupported installation, for any t/s or support.
Else, you may upgrade to LMS 4.2 which is supported on ESXi 5.0.
-Thanks
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
