Community Helping Community
626
Beginner
Prime LMS 4.2.1 Dashboard problem
I've a Dashboard problem in LMS 4.2.1
I can't create or delete dashboards in my Username I've try to delete the username and creating it again and it didn't solve the problem,
the same error message appears
here is the error message
can someone advise me how to handle this problem
thanks
Everyone's tags (4)
1 ACCEPTED SOLUTION
Highlighted
Contributor
In LMS 4.1, this was a bug with "CSCtq29347"  which is URL redirection issues.
Try the following steps:
1. Stop the daemon manager.
2. After stop the daemon manager, back-up the portal.properties and portal.script from the location NMSROOT\MDC\tomcat\webapps\cwportal\db\
3. Copy the portal.properties and portal.script file from the location NMSROOT\MDC\tomcat\webapps\cwportal\db\orig\ and replace it to NMSROOT\MDC\tomcat\webapps\cwportal\db\
4. Then start the daemon manager and check.
After resetting the Portal database the custom created dashboards won't be available.  Don't create an  Embedded/URL dashboard as a first dashboard. Create  a portlet dashboard first and afterwards create any type(Embedded/URL/portlet) of the dashboard.
2 REPLIES 2
Highlighted
Contributor
Beginner
Hi Nael,
Sorry for the late response,
it help.
Content for Community-Ad
July's Community Spotlight Awards
