Prime LMS 4.2.3 + No devices associated to pollers
Jason Fraioli
Participant
Participant
The Monitor -> Dashboards -> Monitoring screen is telling me that there is no performance or availability data because there are no configured pollers.  When I look at the pollers configuration, I don't have a create button, nor can I edit any of the default pollers.  Has polling or performance logging been disabled somewhere else in LMS?  Please see the attached screenshots.
Thanks!
Vinod Arya
Check if IPSLA Performance Management is enable for LMS.
Till LMS 3.2 there were 8 different applications like Common Services, Portal and applications covering functionalities in FCAPS model.
LMS 4.2 removes application boundaries and provides tighter integration among the components. It groups all the related functionalities in one place, thus making the product more user friendly.
LMS 4.2 consists of the following five functionalities:
Inventory, Config and Image Management
Network Topology, Layer 2 Services and User Tracking
Fault Management
Device Performance Management
To view the functionality settings:
Select Admin > System > Device Management Functions.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Vinod Arya
Fault Management
-Thanks
Thanks Vinod!
Recognize Your Peers
