11-07-2014 02:09 AM
Hi @all,
I am uisng Prime LMS 4.2.5. We want to monitor the performance of interfaces (in and out discards, utilization etc.)
Is it possible to select other interfaces than the "Link Ports"? I want to monitor some server ports.
I have created my own group, but this one cannot be selected in the threshold configuration.
Joerg
11-07-2014 08:34 AM
You can select the other ports/interfaces when while creating poller, you'll see following options :
Poll by Pattern
Select patterns on which you want to query devices and poll instances
Poll all Instances
Poll all instances of the selected template on the selected devices
Poll by User Selection
Select the instances on which you want to poll the devices
Select the Poll by user Selection to select the desired interfaces. It Polls the selected instances of the device. You cannot select this preference type for Device Groups and Port Groups data sources.
-Thanks
Vinod
11-10-2014 12:36 AM
Hi Vinod,
you are right, for the poller it is correct. But I want do define thresholds. And there I cannot select my own port groups.
Any idea?
regards
Joerg
11-10-2014 08:12 AM
Do you mean you're able to select the desired Port Channel Group while creating Poller normally, but not when you're using option Threshold Only.
> Please share details on what kind Template/Poller are you trying to deploy?
> Can you try to use another Template along with the existing one and check if you see desired interfaces/port channel there?
> Is it happening for all the devices? Or just one/few?
Please try to complete a fresh inventory collection for the problematic device and try again to see it fixes the issue. Do share if the inventory job is failure/successful.
-Thanks
Vinod
11-11-2014 01:05 AM
