michal.adam
Beginner
Prime network control system appliance (NCS)
i have a new cisco prime network control system appliance (NCS)
I completed the initial installation however post installation it performed a reboot and is now stuck at Init Level 3.
I have restarted the machine several time but the same result.
1 REPLY 1
Marvin Rhoads
VIP Community Legend
Umm a new appliance should have had the application pre-installed. Were you upgrading?
In either case, you'll probably need to open a TAC case. Even without Smartnet you should have at least 90-day warranty support
