Hi! Can you help me with troubleshoot, I don't know where I am wrong?I don't see on BUH2, route from BUH1 (81.1.210.0/24).I attached config from BUH1, BUH02, ClinicaA01, ClinicaB02, P0.
The content you are looking for has been archived. View related content below.
Hello,are there any best practices on the authentication timer settings?Is it common to let the settings for authentication timer reauthenticate and authentication timer restart on defaults?RegardsSebastian
Hello guys. What questions should I ask when establishing network for company?.
HelloSo I wanna verify if maybe this is normal function or a misconfiguration on ACL or a missing one but a DMZ host is mounting a [Samba Share] from an INSIDE Host, on completely different Network, but NO ACL Permitting it... Any ideas?ISR C1111 ...
Mods blocked last post, so trying again. No info here is confidential.Hoping someone can shed some light. I have a switch in a remote location that I can connect to via SSH, but once connected I am unable to run *any* commands. I cannot do "show run....
Hello Guys,Below playbook is not working, kindly assist look into it and advise. Thanks.Getting below error :-What could I be doing wrong?
I’m not sure if I’m posting this in the right spot; I’m new to this needing help with setup of a device. I’ve been trying and failing at setting up my 5506. I have a few questions I think if I can get cleared up I can maybe get this working. Please h...
PI version 3.10 , I configured an SMTP server in "Administration/Settings/System Settings/Mail Server Configuration" and then clicked "Test" but nothing happen,I never received the test mail.PI alarm said:System with IP Address '192.168.99.210' faile...
Hello Techies,I am facing sudden p2p down issue where i have advertised all my ip pools between cisco ASR and juniper router.Checking the log I found below logs %IOSXE-5-PLATFORM: F0: cpp_cp: QFP:0.1 Thread:076 TS:00014740836682289247 %PUNT_INJECT-5-...
Hello all,I am building a network with the following equipment and I would like to have assistance with the some configurations.- NetGate 6100 Firewall- A Cisco 2911 router- A Cisco Catalyst 3750G switch- 5 Cisco Catalyst 2960 48 ports switches- Publ...
I saved the project normally yesterday and when i went to open it this morning I got this error message. Is there anything I can do to recover my project?
hi, so i just got fibre at my place, i live in a 3 story home, the isp modem is in the first floor and i have a liveplug that sends the internet to the 3rd foor where i have my man cave, from the live plus, i have a tp link modem thats configured an ...
I created a playbook for cisco router configuration backup but after executing my command below error occurred.i'm a new user for Ansible hence please help me to solve this problem. fatal: [xx]: FAILED =>["changed": false, "msg": "unable to elevate p...
i can access to asa without enable password by under config.but if i access to FXOS, and change to ASA from FXOS by command(change to asa)the system require the enable password.how can i access the ASA from FXOS without enable password? aaa-server ta...
We shall install a lot of NCS-520 normaly it get the config over ZTP, but by default it starts up with metroaccess that is not supporting BGP etc. I want to save the 10 min for etch for the reboot to do the change to metroipaccessWe will make a softw...
Subject | Author | Posted |
03-28-2024 07:54 AM | ||
03-20-2024 06:23 AM | ||
03-13-2024 04:08 AM | ||
03-07-2024 08:40 AM | ||
03-07-2024 04:55 AM |
User | Count |
8 | |
7 | |
3 | |
3 | |
2 |
