07-03-2007 01:39 AM
I have problem with installing of Multi NFC 6.0 - I can`t find the install script for informix DB - ids_install in the MNFC tar archive.
07-09-2007 08:31 AM
Step 1 Log into the host as root.
Step 2 Insert the DVD in to the drive.
Step 3 Navigate to the CSCOmnfc-6.0.0-31-standard directory using cd.
Step 4 Run MNFC_setup.sh. The image is installed to /opt/CSCOmnfc.
Step 5 When prompted, specify the following:
?The OS user id to own the $MNFC_DIR subdirectory and to run the MNFC server.
?The version of JRE to be used for MNFC server if more than one version is available.
?Whether you want the MNFC application to start up when the server host is rebooted.
07-09-2007 09:56 PM
I have the bad installation archive - incomplete.
