02-22-2010 11:46 PM
Hi all,
In Common services I have problems discovering some pix firewalls, running 6.3(5) software. I have a SNMP tool that can discover the firewalls if i'm using SNMP version 1. I don't have the option to choose version 1 in Cisco Works (except if i do a SNMP walk from the device center, then it works. In device center I can choose version 1). In the discovery settings, I can only choose version 2c or 3.
Any good ideas besides opgrading the firewall softvare
Jesper
02-23-2010 06:11 AM
According to the bug notes, Common Services 3.3 should have support for SNMPv1 device discovery:
So if you can upgrade to LMS 3.2, that'd be one way to work around upgrading the PIX.
02-24-2010 06:35 PM
You're absolutely right. I actually filed a bug for this CSCsu82153. The fix was implemented in LMS 3.2 which offers the ability to fall back from SNMPv2c to SNMPv1.
