Problems restoring from backup
lusbyr
I am trying to restore a Ciscoworks LMS 3.2 configuration from backup.  However, I keep getting this error during the RME restore.
This is from the backup log...
[Tue Feb 2 09:58:16 2010] CCR updation for PSIRT completed.
ADDRESOURCE[CCREntry[RME_CRI,Configurations,Custom,cco,,Psirt_Option,,,,FALSE]]: CCRResponse[2;The entry already exists. Unable to add entry CCREntry[RME_CRI,Configurations,Custom,cco,,Psirt_Option,,,,FALSE].]
ADDRESOURCE[CCREntry[RME_CCJS,Configurations,Custom,true,,VNMPurgeEnabled,,,,FALSE,DefaultData=false]]: CCRResponse[0;]
ADDRESOURCE[CCREntry[RME_CCJS,Configurations,Custom,true,,IPMPurgeEnabled,,,,FALSE,DefaultData=false]]: CCRResponse[0;]
ADDRESOURCE[CCREntry[RME_SYSLOGANALYZER,Configurations,Custom,5,,THREAD_NUM,,,,FALSE]]: CCRResponse[0;]
ADDRESOURCE[CCREntry[cwhp,Custom,Custom,TRUE,,CSSCPServer,,,,FALSE]]: CCRResponse[2;The entry already exists. Unable to add entry CCREntry[cwhp,Custom,Custom,TRUE,,CSSCPServer,,,,FALSE].]
ADDRESOURCE[CCREntry[RME_ICS,Configurations,Custom,0,,eox_soft_last_updated_time,,,,FALSE]]: CCRResponse[0;]
[Tue Feb 2 09:58:18 2010] Backup version: 4.2
[Tue Feb 2 09:58:18 2010] Current version: 4.3
[Tue Feb 2 09:58:18 2010] Successfully updated CCR entry
[Tue Feb 2 09:58:18 2010] No need to update the incremental ccr
[Tue Feb 2 09:58:18 2010] No need to update the ccr
[Tue Feb 2 09:58:18 2010] This is Restore
Unable to start :EssentialsDM
at com.cisco.nm.rmeng.migration.MigrMain.callAppPreMigration(MigrMain.java:386)
at com.cisco.nm.rmeng.migration.MigrMain.main(MigrMain.java:591)
The CiscoWorks Daemon Manager service is stopping.........................
The CiscoWorks Daemon Manager service was stopped successfully.
[Tue Feb 2 10:04:56 2010] Going to write to file
[Tue Feb 2 10:04:56 2010] Written to file
Logger Updated successfully
[Tue Feb 2 10:04:56 2010] Logger Updated successfully
[Tue Feb 2 10:04:56 2010] rmelog.cfg is copied successfully
[Tue Feb 2 10:04:56 2010] Its WINDOWS ....
[Tue Feb 2 10:04:56 2010] ------------------------------------------------------------------------------
[Tue Feb 2 10:04:56 2010] Execution of doRestore rmeng :: restore.pm, completed.
[Tue Feb 2 10:04:56 2010] Unloading Campus Manager restore.pm's functions
ERROR: doRestore of [Resource Manager Essentials] had some errors.
[Tue Feb 2 10:04:56 2010] Check the log file for details
[Tue Feb 2 10:04:56 2010] <Deleting directory F:\CSCOpx\tempBackupData>
[Tue Feb 2 10:04:56 2010] [ rd /s /q F:\CSCOpx\tempBackupData ]
[Tue Feb 2 10:10:31 2010] <Deleting directory F:\CSCOpx\tempBackupData, completed>
[Tue Feb 2 10:10:31 2010] <Restore stoped at 2010/02/02 10:10:31>
Restore from backup 'F:\CW_Backup' started at: 2010/02/02 10:40:47
What does the message "Unable to start: Essentials DM" mean and how do I get the restore to complete successfully?
Thanks.
17 Replies 17
I am seeing some registry keys pertaining to crypto that may be relevant to the problem.  You should compare the keys under HKLM\SOFTWARE\Policies\Microsoft\Cryptography to those of a working server.
greenamit
I'm joining this thread as I'm having the same sort of issue.
However, I am running LMS 3.2 on Solaris 10.
I intalled 3.2 and tried to restore from a backup I took on the same server after installation (a successfull backup).
Here is the relevant bit from restorebackup.log:
Directory  /opt/CSCOpx/rigel/scripts/rme/dbupgrade/schemachange will be  processed
Updating schema From File: /opt/CSCOpx/rigel/scripts/rme/dbupgrade/schemachange/rme_schemaChanges.sql
    Stopping database engine rmengEng
SQL Anywhere Command File Hiding Utility Version 10.0.1.3830
[Mon Feb 22 11:05:52 2010] Successfully updated the db tables
70% of RME  Restore completed
[Mon Feb 22 11:05:52 2010] Setting VM_MIN_HEAP to 128
[Mon Feb 22 11:05:52 2010] Setting VM_MAX_HEAP to 512
[Mon Feb 22 11:05:52 2010] Setting RETRIES to 15
[Mon Feb 22 11:06:01 2010] Daemon Manager started successfully
[Mon Feb 22 11:06:01 2010] Checking if RME Database Engine is up  and running
INFO:Daemon Manager is processing other tasks in the queue.Please  try again later.
[Mon Feb 22 11:11:01 2010] Process RMEDbEngine is not running or  never started
[Mon Feb 22 11:11:01 2010] Will check after 60 seconds
[Mon Feb 22 11:17:01 2010] Process RMEDbEngine is not running or  never started
[Mon Feb 22 11:17:01 2010] Will check after 60 seconds
[Mon Feb 22 11:23:02 2010] Process RMEDbEngine is not running or  never started
[Mon Feb 22 11:23:02 2010] Will check after 60 seconds
[Mon Feb 22 11:27:36 2010] Process RMEDbEngine is running normally
90% of RME  Restore completed
[Mon Feb 22 11:27:36 2010] Value of PX_DATA_DIR is:  /var/adm/CSCOpx/files
[Mon Feb 22 11:27:36 2010] CMF Version is : 3.3.0
[Mon Feb 22 11:27:36 2010] CMF Backup Version is: 3.3
[Mon Feb 22 11:27:36 2010] Going to update CCR entries for PSIRT
[Mon Feb 22 11:27:36 2010] CCR updation for PSIRT completed.
[Mon Feb 22 11:27:36 2010] Backup Version: 4.3 and Current Version:  4.3 are same
[Mon Feb 22 11:27:36 2010] No need to update the incremental ccr
[Mon Feb 22 11:27:36 2010] No need to update the ccr
[Mon Feb 22 11:27:36 2010] This is Restore
Daemon Management stopping. This may take a few minutes.
[Mon Feb 22 11:37:50 2010] Going to write to file
[Mon Feb 22 11:37:50 2010] Written to file
[Mon Feb 22 11:37:50 2010] Logger Updated successfully
[Mon Feb 22 11:37:50 2010] rmelog.cfg is copied successfully
[Mon Feb 22 11:37:50 2010] Its SOLARIS ....
[Mon Feb 22 11:37:50 2010] NMSROOT for file  permission==>/opt/CSCOpx/
[Mon Feb 22 11:37:52 2010] ------------------------------------------------------------------------------
[Mon Feb 22 11:37:52 2010] Execution of doRestore rmeng :: restore.pm, completed.
[Mon Feb 22 11:37:52 2010] Unloading Campus Manager restore.pm's functions
[Mon Feb 22 11:37:52 2010]        Check the log file for details
[Mon Feb 22 11:37:52 2010] [ rm -rf /opt/CSCOpx/tempBackupData ]
Here is pdshow output:
Process= RMEDbEngine
        State  = Program started - No mgt msgs received
        Pid    = 10170
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:02
        Stop   = Not applicable
        Core   = Not applicable
        Info   = Application started by administrator request.
        Process= ANIDbEngine
        Pid    = 10180
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:06
        Process= WlseUHIC
        State  = Running normally
        Pid    = 10201
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:10
        Info   = Started.
        Process= CmfDbEngine
        Pid    = 10202
        RC     = 0
        Signo  = 0
        Process= CmfDbMonitor
        Pid    = 10212
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:14
        Info   = DbMonitor Running Normally.
        Process= IpmDbEngine
        Pid    = 10213
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:15
        Process= OpsxmlDbEngine
        Pid    = 10223
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:19
        Process= EPMDbEngine
        Pid    = 10233
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:23
        Process= INVDbEngine
        Pid    = 10243
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:27
        Process= FHDbEngine
        Pid    = 10253
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:31
        Process= ESS
        Pid    = 10263
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:35
        Process= EssMonitor
        Pid    = 10264
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:39
        Info   = ESS is fully up now !
        Process= EventFramework
        Pid    = 10265
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:49
        Process= SyslogCollector
        Pid    = 10266
        RC     = 0
        Signo  = 0
        Process= MACUHIC
        Pid    = 10267
        RC     = 0
        Signo  = 0
        Info   = Started.
        Process= UTLITE
        Pid    = 10268
        RC     = 0
        Signo  = 0
        Info   = Started.
        Process= VNMServer
        Pid    = 10269
        RC     = 0
        Signo  = 0
        Process= EPMServer
        State  = Administrator has shut down this server
        Pid    = 0
        RC     = 1
        Signo  = 0
        Start  = 02/22/10 12:13:30
        Stop   = 02/22/10 12:13:32
        Process= AdapterServer
        State  = Never started
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Info   = Not applicable,
        Process= AdapterServer1
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= FHServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= PMServer
        Pid    = 10271
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:53
        Info   = PMServer is up and running
        Process= DFMLogServer
        Pid    = 10272
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:52:57
        Process= DFMCTMStartup
        Pid    = 10273
        RC     = 0
        Signo  = 0
        Process= FHPurgeTask
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= DfmBroker
        Pid    = 10274
        RC     = 0
        Signo  = 0
        Process= DfmServer
        Pid    = 10302
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:53:01
        Info   = DfmServer initialized OK.
        Process= DfmServer1
        Pid    = 10303
        RC     = 0
        Signo  = 0
        Info   = DfmServer1 initialized OK.
        Process= DFMMultiProcLogger
        Pid    = 10304
        RC     = 0
        Signo  = 0
        Process= ProcSysBus
        Pid    = 10305
        RC     = 0
        Signo  = 0
        Process= OpsXMLRuntime
        Pid    = 10374
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:53:05
        Process= CWAPublisher
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 12:13:10
        Stop   = 02/22/10 12:16:29
        Process= CSDiscovery
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= DCRDevicePoll
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= CSRegistryServer
        Pid    = 10380
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:53:09
        Info   = CSRegistryServer is running
        Process= Tomcat
        Pid    = 10381
        RC     = 0
        Signo  = 0
        Process= TomcatMonitor
        Pid    = 10423
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:53:13
        Info   = Tomcat Server up
        Process= Apache
        Pid    = 0
        RC     = 1
        Signo  = 0
        Start  = 02/22/10 12:45:05
        Stop   = 02/22/10 12:45:08
        Process= DCRServer
        State  = Waiting to initialize.
        Pid    = 10458
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 11:56:59
        Process= CMFOGSServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= CampusOGSServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= EssentialsDM
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= RMEOGSServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= PMCOGSServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= ICServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= ConfigMgmtServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= UTManager
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= TISServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= DFMOGSServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= NOSServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= PTMServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= InventoryCollector
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= Interactor
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= InventoryCollector1
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= Interactor1
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= LicenseServer
        Pid    = 10473
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 12:01:59
        Process= FDRewinder
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= NameServer
        Pid    = 10474
        RC     = 0
        Signo  = 0
        Process= NameServiceMonitor
        Pid    = 10477
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 12:02:03
        Info   = NameServer is fully up now !
        Process= EDS
        Pid    = 10478
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 12:02:07
        Info   = Initialization complete
        Process= ANIServer
        State  = Running with busy flag set
        Pid    = 10479
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 12:02:35
        Info   = ANIServer started.
        Process= UTMajorAcquisition
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= EDS-GCF
        Pid    = 10480
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 12:02:39
        Info   = GCF Initialization complete at Mon Feb 22 12:03:04  IST 2010
        Process= jrm
        Pid    = 10481
        RC     = 0
        Signo  = 0
        Process= CTMJrmServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= ChangeAudit
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= SyslogAnalyzer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= DataPurge
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 12:13:06
        Stop   = 02/22/10 12:13:42
        Info   = DataPurge initialization completed at Mon Feb 22  12:13:42 IST 2010.
        Process= IPMProcess
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= IPMOGSServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= diskWatcher
        Pid    = 10483
        RC     = 0
        Signo  = 0
        Start  = 02/22/10 12:02:58
        Info   = diskWatcher initialized OK.
I attached EssentialsDM.log and EssentialsDM_Server.log logs.
After the restore fails some processes are not starting (Apache, EssentialsDM etc...).
Can you please let me know how to overcome this issue?
BTW, I'm not sure if I enabled HTTPS or not before I took the backup (if that matters).
Amit
Amit,
Check two things...
1.  Make sure that casuser has permissions to access the directory the backup is stored in.
2.  If Apache is not starting up in https mode, then comment out the SSLCertificateChainFile line in NMSROOT/MDC/Apache/conf/httpd.conf, and Apache should start in SSL mode.
Let me know if this works for you.
Thanks.
Bob
