Problems with master ntp server
cdgsoportevip
Visitor
Hello community,
I have a question about ntp server, because I don't know if the our NTP service is properly configured and working correctly.
I have a Cisco Catalyst  WS-C4507R that it has a master ntp server configured and that works as ntp server to other servers.
And It also has two ntp servers configurated:
switch1#show ntp associations
      address    ref clock  st   when   poll   reach   delay   offset   disp
*~127.127.7.1  127.127.7.1   4     56     64     377     0.0     0.00    0.0
~172.27.0.102  127.127.1.0  11    155   1024     377     3.4    12.99    1.6
~172.27.0.103  127.127.1.0  11    154   1024     377     2.9     6.46    0.6
* master (synced), # master (unsynced), + selected, - candidate, ~ configured
switch1#show ntp status
Clock is synchronized, stratum 5, reference is 127.127.7.1
nominal freq is 250.0000 Hz, actual freq is 250.0071 Hz, precision is 2**19
reference time is E28265A0.26A8A8A6 (20:08:32.151 METDST Wed Jun 3 2020)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.02 msec, peer dispersion is 0.02 msec
And the configuration in our switch over ntp is:
switch1#show running-config
process cpu threshold type total rising 80 interval 50
ntp clock-period 17179376
ntp master 5
ntp update-calendar
ntp server 172.27.0.102 prefer
ntp server 172.27.0.103
end
I know the address 127.127.7.1 is the reference clock address for the Cisco router when the router acts as a NTP master. And I have read in another Cisco community forum that If the router has not been synchronized with any NTP server, the router will use this address as the Reference ID. But I have the address 172.27.0.102 configured as the reference.
Could you tell me if this configuration is correct? Shouldn't the master be the server 172.27.0.102 because this is the one that we have configured as prefer? Is possible that the router has not been synchronized with any NTP server?
Thanks in advance.
0 Replies 0
