I have an S7 410 PLC communicating to Profinet IO through 2 Catalyst 9300. When I complete the profinet IO ring The whole network comes down. If the loop isn't completed the network is fine. Is there anything on the Catalyst 9300 configuration that needs to be set up?
I believe that the loop detection packet isn't being sent through the Profinet IO.
Cheers
