Proper bandwidth calculator/conversion tool.
infreon-cco
I hope this is the correct forum for this but here goes. I need to find a bandwidth calculator or conversion tool that also takes into effect overhead. It seems as though there aren't any online calculators that do this properly. I found one here http://www.easycalculation.com/bandwidth-calculator.php
but am not sure if the calculations are correct. Is there anything anyone else can recommend? Basically I want to monitor my DSL clients and need to be able to convert their DSL profile from kilobits to bytes for my monitoring systems.
Thanks.
0 Replies 0
