Showing results forĀ
Search instead forĀ
Did you mean:Ā
PSIRT and EOX reports missing
MUQ_1899_
Hello, we have a customer with a physical Cisco Gen 2 Prime Infrastructure Server and they want to generate reports of this type. To do that we have to turn on the Compliance Services feature from Administration > System Settings > Sever but this option is missing. Do I have to do something preliminary or the Cisco’s docs are not up to date and this feature is missing from PI 3?
We had a problem with getting our reports working.  Turns out it is a bug: CSCux44760
I had to open a TAC case to get it resolved.
Mark Malone
Hi No thats exactly how i turned ours on Prime 3.0 just followed the doc and once i did compliance section appeared and in reports section PSIRT and EOX were there , i wasnt involved in our original licenses but i wonder if its something to do with that
Ricardo Ramos
Hello, I have a similar problem with Cisco PI 2.2
When I go to the Administration > Server Settings > Compliance Service, the option is missing and appears this message "This feature is being re-architected and will be available in a future release."
Hey its not in 2.2 by default Cisco have it disabled , you need 3.0 for compliance to function
Important Notes
This section contains important notes about Cisco Prime Infrastructure.
  • Due to a technical/architectural problem, the Compliance Service process is disabled in Prime Infrastructure 2.2. As a result of this, the PSIRT compliance reports and the EoX device reports are not available in Prime Infrastructure 2.2. These reports are expected to be available in the next version of Prime Infrastructure.
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-2/release/notes/cpi_rn.html
