12-23-2014 01:16 PM
After upgrade to 7.0 I lost ability to use raw_input in my scripts ((. It seems that there is no echo when I typing. Anybody know any workaround?
Many of my scripts are interactive and asking user some questions. All of them do not work after upgrade (((
Solved! Go to Solution.
12-23-2014 07:10 PM
This sounds like CSCug13717, which looks to be fixed in 7.1.
12-23-2014 07:10 PM
12-24-2014 12:25 AM
Thank you very much.
I've just checked. Unfortunately it is not resolved in n5000-uk9.7.1.0.N1.1.bin yet ((.
Will wait (((
12-24-2014 01:00 PM
The fixed version is kind of hard to decipher. It may be fixed in the next 7.1 release. But it might be best to open a TAC case so this can be properly tracked to make sure it's being fixed in the N5K branch.
