Python raw_input in nxos 7.0
Aleksandr Serov
After upgrade to 7.0 I lost ability to use raw_input in my scripts ((. It seems that there is no echo when I typing. Anybody know any workaround?
Many of my scripts are interactive and asking user some questions. All of them do not work after upgrade  (((
Joe Clarke
This sounds like CSCug13717, which looks to be fixed in 7.1.
Joe Clarke
Thank you very much.
I've just checked. Unfortunately it is not resolved in n5000-uk9.7.1.0.N1.1.bin yet ((.
Will wait (((
The fixed version is kind of hard to decipher.  It may be fixed in the next 7.1 release.  But it might be best to open a TAC case so this can be properly tracked to make sure it's being fixed in the N5K branch.
