Mason Tu
Beginner
QPM 4.0 Can't use hostname as Primary Device Name
I am using LMS QPM 4.0. And I got a problem adding devices.
First of all, I use common service -> DCR to add devices manually.
Then I try to import devices from DCR to Qos Policy Manager.
The import is good but the Primay Device Name in QPM becomes IP address rather than hostname.
When I try to edit the device in "Managed Devices" , I couldn't edit the Primary Device Name value.
So I delete device and try to add devices manually in QPM with hostname, but it shows DCR Error in status.
If I add device manually in QPM with IP address , the status is OK . But it's not what I want.
Does anyone know how to use hostname as Primary Device Name in QPM?
Any advice is welcome.
Thanks!!!
0 REPLIES 0
Content for Community-Ad
