12-15-2010 12:47 AM
Hi all. I have a task to use a background image in LMS3.2 in CM. I understand how to import it. But i can't understand how to fix it,because topology is fixed and a background image is not. So when i want to zoom in/out, my topology become larger or smaller,and the background image is static/ How can i fix this problem? Thanks all.
12-15-2010 04:41 AM
You can't. The background implementation was minimal.
Cisco can say it supports a background image.
That like this, it is not done in a usefull way is something you should relay to your cisco account manager. (and hope for the best)
Cheers,
Michel
12-17-2010 01:43 AM
Thanks.
