question about subnetting with VLSM
jpcapobianco
hi,
i have a question about subnetting using VLSM
i start from
192.168.15.0  /24
then use the  /26  prefix with this address and i have:
192.168.15.0       /26
192.168.15.64     /26
192.168.15.128   /26
192.168.15.192   /26
now i re-subnet one of these subnets:
192.168.15.128   /26 and i use /30
how many subnet can i obtain ?
i think 16 because i'm borrowing other 4 bits from 26 to 30.
but i'm not sure if i have to consider the initial /24 , in that case the subnet will be 64.
can someone explain to me ?
do i have to considere 2^4 borrowed from /26
or 2^6 borrewed from /24  ???
thanks
Marvin Rhoads
Each /30 uses four numbers - the network number, the broadcast address and two host addresses.
You are working with the range from 128-191 = 64 numbers. 64 numbers / 4 numbers per /30 network = 16 each /30 networks
