the main 'drawback' of the management interface is that traffic cannot be routed between the management interface and other interfaces. So if you have enough ports available, using a different port is definitely an option. Either make the port you want to use as a routed port, or assign a (management) Vlan to the port and configure a Vlan interface (SVI), which then can be accessed through SSH or the web interface.
I have a feeling that you are going to use this for a home network and not in a business environment ?
