Question regarding MPLS L3VPN
asuka55
If a customer has 2 sites and they’re both connected to each other via the ISP MPLS backbone, can the customer use the same private IP range in both sites? If yes, then how would that work if a user in site A wants to connect to a server in site A that has an ip address of 192.168.10.10 and also wants to connect to a server in site B that has the same IP address as the server in site A. Any help explaining this would be really appreciated.
Can not use same subnet in two sites use l3vpn (mp-bgp)
Can use same subnet in two sites if use l2vpn (vpls)
Confuse point, but the doc. Say we can use same subnet in different sites!!!
Yes that true if these sites not connect via l3vpn.
Hi @MHM Cisco World ,
Wrong post. Sorry.
Sorry I think you write in wrong post
MHM
