"SER Parity Check Error"
WGL_BK
I'm having a bad week - my ISR 4331 router has been flooding my syslog server with these messages non-stop and I can't seem to find why:
Sep 29 15:38:54.415: %IOSXE-3-PLATFORM: R0/0: bcm_switch: unit 0 SER_ERROR_0 REG unexpected NACK failure!
Sep 29 15:38:54.415: %IOSXE-3-PLATFORM: R0/0: bcm_switch: SER Parity Check Error.
Sep 29 15:38:54.415: %IOSXE-3-PLATFORM: R0/0: bcm_switch: SchanTimeOut:soc_schan_op operation timed out
Sep 29 15:38:54.416: %IOSXE-3-PLATFORM: R0/0: bcm_switch: unit 0 SER_ERROR_0 REG SCHAN NACK analysis.
Sep 29 15:38:54.416: %IOSXE-3-PLATFORM: R0/0: bcm_switch: unit 0 SER_ERROR_0 REG unexpected NACK failure!
Sep 29 15:38:54.416: %IOSXE-3-PLATFORM: R0/0: bcm_switch: SER Parity Check Error.
Sep 29 15:38:54.417: %IOSXE-3-PLATFORM: R0/0: bcm_switch: SchanTimeOut:soc_schan_op operation timed out
Sep 29 15:38:54.418: %IOSXE-3-PLATFORM: R0/0: bcm_switch: unit 0 SER_ERROR_0 REG SCHAN NACK analysis.
Sep 29 15:38:54.418: %IOSXE-3-PLATFORM: R0/0: bcm_switch: unit 0 SER_ERROR_0 REG unexpected NACK failure!
Sep 29 15:38:54.418: %IOSXE-3-PLATFORM: R0/0: bcm_switch: SER Parity Check Error.
Sep 29 15:38:54.418: %IOSXE-3-PLATFORM: R0/0: bcm_switch: SchanTimeOut:soc_schan_op operation timed out
Sep 29 15:38:54.420: %IOSXE-3-PLATFORM: R0/0: bcm_switch: unit 0 SER_ERROR_0 REG SCHAN NACK analysis.
Sep 29 15:38:54.420: %IOSXE-3-PLATFORM: R0/0: bcm_switch: unit 0 SER_ERROR_0 REG unexpected NACK failure!
Sep 29 15:38:54.420: %IOSXE-3-PLATFORM: R0/0: bcm_switch: SER Parity Check Error.
Sep 29 15:38:54.420: %IOSXE-3-PLATFORM: R0/0: bcm_switch: SchanTimeOut:soc_schan_op operation timed out
Sep 29 15:38:54.421: %IOSXE-3-PLATFORM: R0/0: bcm_switch: unit 0 SER_ERROR_0 REG SCHAN NACK analysis.
Sep 29 15:38:54.421: %IOSXE-3-PLATFORM: R0/0: bcm_switch: unit 0 SER_ERROR_0 REG unexpected NACK failure!
Sep 29 15:38:54.422: %IOSXE-3-PLATFORM: R0/0: bcm_switch: SER Parity Check Error.
The IOS version:
Cisco IOS XE Software, Version 16.09.04
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.4, RELEASE SOFTWARE (fc2)
I've found this Parity Errors Troubleshooting Guide but I'm not seeing my exact error, I'm a little way about messing around in an area I'm unsure of. Hoping someone can point me in the right direction.
Mark Elsen
 - Looks like a hardware error , single parity errors usually don't affect operation. If the device is currently mission critical no further action may be taken/needed. Otherwise you might contemplate cold-reboot (with power cycle) , check if problem remains in place or not.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thanks, I'll try to reboot overnight and see.
You were right, after the reboot I've seen no further errors. Thank you very much.
Rich R
Just to add to this (as we've just seen the problem and a reboot cleared it)- this seems to be addressed by https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv98528 which is fixed in later IOS-XE releases.
