Radius works with L2TP VPN but not ASDM
chemdream
Something very strange started happening. I'm looking for a sanity check.
We currently use a Radius-As-A-Service to provide authentication for our VPN on a Cisco ASA and ASDM access to that same ASA.
Nothing changed on the radius side at all.
Both VPN and ASDM use the exact same Radius Object in the ASA. VPN currently still works perfect.
However, out of nowhere, ASDM access doesn't! I get a "IP is unreachable" error. But if I try VPN, it works perfect. Same IP address!
I'm pounding my head against the table here. I'm sure I changed one little thing, even though I don't remember changing anything.
To add to this, it's not falling back to local user accounts even though it's set to.
Any one have any ideas?
Captain HoOmi
Whats the ASA and ASDM firmware version? Had a similar issue ( not exactly this) with the 9.12.2. Downgrade to 9.12.1 fixed it
** Please rate this post or accept the solution if it helped! :) **
